Motors
Tach for outboard
<blockquote data-quote="wmk0002" data-source="post: 398893" data-attributes="member: 13975"><p>You would think so but it worked fine on my mower with both wires still in the shielding and wrapped around my plug wire on my mower (so neither grounded). Anyways, I am going to cut into an old transducer wire tonight and see if it looks like it will work to try to extend it. If so I will extend both wires and wrap both around the plug wire and see what happens. If that doesn't work I will run one to ground to see if that remedies it. I'll post my results so maybe it can help someone else down the road.</p></blockquote><p></p>
[QUOTE="wmk0002, post: 398893, member: 13975"] You would think so but it worked fine on my mower with both wires still in the shielding and wrapped around my plug wire on my mower (so neither grounded). Anyways, I am going to cut into an old transducer wire tonight and see if it looks like it will work to try to extend it. If so I will extend both wires and wrap both around the plug wire and see what happens. If that doesn't work I will run one to ground to see if that remedies it. I'll post my results so maybe it can help someone else down the road. [/QUOTE]
Motors
Tach for outboard
