I recently purchased a MK Maxxum 70lb thrust.
It comes with 6 screws for installation and recommends all 6 be used, if possible but 4 will do.
I contacted MK, I gave them the background and they said 4 will be fine.
The reason I may not use six is because of the difficulty using 6 would incur. I would need to drill holes to access under bow area in order to tighten the lock nuts.
Should I just go for broke and install with 6 OR should I simply attach it with 4 and address any problem which may occur, down the road.
Your input is appreciated!
thanks
thanks
