tracker 1542
<blockquote data-quote="reedjj" data-source="post: 188312" data-attributes="member: 4585"><p>What thickness plywood (or other material) did you use on your floors and decks? Did you use aluminum supports or 2x2's, 2x4?</p><p></p><p>And like HawgCalla, I am curious as to how stable it is and how deep it sits (draft) in the water. </p><p></p><p>Mine is an Alumacraft 1542 and I decked my front halfway to the middle bench with 15/32nds ply, and the rear with 11/32 ply. I used 11/32nds on the floors to save weight with foam under it to support the floor and to deaden the sound. </p><p></p><p>I have not had mine in the water yet and Im curious as to how it will sit and how stable it will be with the extra weight.</p></blockquote><p></p>
[QUOTE="reedjj, post: 188312, member: 4585"] What thickness plywood (or other material) did you use on your floors and decks? Did you use aluminum supports or 2x2's, 2x4? And like HawgCalla, I am curious as to how stable it is and how deep it sits (draft) in the water. Mine is an Alumacraft 1542 and I decked my front halfway to the middle bench with 15/32nds ply, and the rear with 11/32 ply. I used 11/32nds on the floors to save weight with foam under it to support the floor and to deaden the sound. I have not had mine in the water yet and Im curious as to how it will sit and how stable it will be with the extra weight. [/QUOTE]
tracker 1542
