Boat House
Tranducer mount ideas
<blockquote data-quote="TNtroller" data-source="post: 373963" data-attributes="member: 4251"><p>You can mount the TD on a TM if you going to have one, or drill some holes on the transom, use 5200 or marine goop to seal the holes from leaks. Lots of people mount some blocks of plastic cutting board material with screws/5200 and then mount the TD bracket to the cutting board material as the 1st location is not always the best if you are after the best HU picture/returns possible. 1/8" can make a considerable difference in the performance of the DF.</p></blockquote><p></p>
[QUOTE="TNtroller, post: 373963, member: 4251"] You can mount the TD on a TM if you going to have one, or drill some holes on the transom, use 5200 or marine goop to seal the holes from leaks. Lots of people mount some blocks of plastic cutting board material with screws/5200 and then mount the TD bracket to the cutting board material as the 1st location is not always the best if you are after the best HU picture/returns possible. 1/8" can make a considerable difference in the performance of the DF. [/QUOTE]
Boat House
