Electrical
Using Boat as Your Ground???
<blockquote data-quote="Hanr3" data-source="post: 81980" data-attributes="member: 1055"><p>Great advise so far.</p><p></p><p>You can reduce the number of wires you run by using one ground wire for two circuits provided the combined load of both circuits is less than the max rating of the wire.</p><p></p><p>For example-</p><p>If you run 16 gauge wire 20 feet to feed your fishfinder and LED lights, one power wire to each, you can use one negative wire for both of them. Say the fishfinder draws 1 amp and the lights draw 3 amps, and the wire is rated for 5 amps. 3 + 1=4 amps which is less than 5 amps. The only other thing is the power and negative wires must be run back to the same battery.</p></blockquote><p></p>
[QUOTE="Hanr3, post: 81980, member: 1055"] Great advise so far. You can reduce the number of wires you run by using one ground wire for two circuits provided the combined load of both circuits is less than the max rating of the wire. For example- If you run 16 gauge wire 20 feet to feed your fishfinder and LED lights, one power wire to each, you can use one negative wire for both of them. Say the fishfinder draws 1 amp and the lights draw 3 amps, and the wire is rated for 5 amps. 3 + 1=4 amps which is less than 5 amps. The only other thing is the power and negative wires must be run back to the same battery. [/QUOTE]
Electrical
