Boat House
wires
<blockquote data-quote="nccatfisher" data-source="post: 465937" data-attributes="member: 10811"><p>Usually will get some black irrigation pipe and run up the side in the channel behind the ribs and put wire inside it. That drip irrigation pipe is extremely thin so it will be flexible and you can fish it through. With two pieces of 8Ga you will most likely have to thread it through prior to working it all as a unit in there.</p></blockquote><p></p>
[QUOTE="nccatfisher, post: 465937, member: 10811"] Usually will get some black irrigation pipe and run up the side in the channel behind the ribs and put wire inside it. That drip irrigation pipe is extremely thin so it will be flexible and you can fish it through. With two pieces of 8Ga you will most likely have to thread it through prior to working it all as a unit in there. [/QUOTE]
Boat House
wires
