Electrical
wiring trolling motor without removing clips
<blockquote data-quote="Dark3" data-source="post: 351008" data-attributes="member: 14036"><p>I did this recently. So I had a about a 20' run (whole circuit) from transom mounted 30lb 30 Amp troller to the deep cycle in front of the front bench. I ran 6GA in a plastic split conduit through the ribs in the side from the deep battery to the starting battery box so that the box would protect the conections. I used a quick connector with 6GA butt connectors to connect the 6 to the quick connects 10ga, liquid tape, real tape, and hid tgem in that back box. [attachment=-1]uploadfromtaptalk1399068620272.jpg[/attachment][attachment=-1]uploadfromtaptalk1399068659910.jpg[/attachment]</p></blockquote><p></p>
[QUOTE="Dark3, post: 351008, member: 14036"] I did this recently. So I had a about a 20' run (whole circuit) from transom mounted 30lb 30 Amp troller to the deep cycle in front of the front bench. I ran 6GA in a plastic split conduit through the ribs in the side from the deep battery to the starting battery box so that the box would protect the conections. I used a quick connector with 6GA butt connectors to connect the 6 to the quick connects 10ga, liquid tape, real tape, and hid tgem in that back box. [attachment=-1]uploadfromtaptalk1399068620272.jpg[/attachment][attachment=-1]uploadfromtaptalk1399068659910.jpg[/attachment] [/QUOTE]
Electrical
