Rear Seat Conversion
NS4Jay
Virginia
LOCATION
Fredericksburg, VA
I have a 1965 Rich Line model 15 (14'3") in my near future. I am wondering the feasibility of removing the back bench seat and putting in seats on both sides of center much like the Lund 14 pictured here. The lower photo is of the Rich Line last summer on a Potomac River ham radio adventure.
You might be best to leave them there and just cut-out the center as needed. Yes, you seats will be 1" taller or so due to the MDO over the existing rear seats, but that's not much. See here for some examples of using 'L'=shaped aluminum angle for bracing. At worst ... maybe you'll need to remove them, but try it this other way 1st, would be my advice, at least for what I'm looking ay via cyber space, LOL!
Borrow a saws all with a fine tooth metal blade and have at it ... !
Anything is possible...however..what is your mechanical skill level and do you have acess to tools? Your boat is more narrow than the Lund in the pic, so there will be a difference in how much room you end up with. A couple cardboard templates might help you see things better !!
7” difference doesn’t seem like much but I don’t have the boat in hand yet. It will be a journey for sure. Thanks.
My friend used plastic composite board for the transom and seat tops. I’m pretty handy in design and building. Plus have friends who can weld aluminum. It will be fun for sure. I’ll think hard before jumping in because the 65’ Rich Line is a classic.
Your proposed modifications look awkward to me. I wouldn't like that and suspect you won't either. I'd leave it alone if I were you.
I didn’t want to say anything negative but, what do like about that seat configuration? It’s seems tippy, sitting on the side of the boat like that.
That is where you balance your load with things like battery, fuel tank, tool box, whatever. When running a tiller, I find it uncomfortable sitting on a cross bench type seat, being able to sit sideways is more comfortable for me anyway. Years back had a small tinnie with a similiar layout, had tank on one side, battery on other side. Very comfortable to drive with a tiller.
Is that a plastic PROP? If so did it come with the engine? My dad had a plastic prop for our old 40 HP Johnson. He later went with aluminum and kept the plastic as a spare, out bottoms were mostly mud and sand though.
Love the SAFETY YELLOW prop...I paint mine (every yr) ... well I love SAFETY YELLOW anything.. so far I have painted...
The prop and the anchor.. .less bumping into when out clamming and stubbing toes...
The tongue of my trailer, and the hitch.. less knee bruising
and the head and pole of my clam rake
Not a bad idea at all...I know how clumsy I can be in tight quarters, have bruises to prove it !!
When I rebuilt the lower (impeller and all seals) and cleaned up the prop, yellow rattle can paint is what I had on hand.
I too paint my props, anchors and chain, but use gloss white ...
Last year was at the local sandbar and a guy stubbed his foot on his own anchor that was dark gray against the dark mud/sand bottom ... and he tore his big toe off ... left hanging by tendons and flesh - can you say OUCH! He could't see his anchor ... or chain!
