Alumacraft 1648 (updated 9/13/11)
Doug
Alumacraft 1648 (updated 9/7/10)
Post by Doug »
Mod looks great. How did she float, any leaks?
Doug
raven174us
Post by raven174us »
That's a big difference from where you started. It looks great!
Howard
Post by Howard »
Doug - floats great, 2 small leaks when I went out by myself. One rivet and a seam about a inch long. Both on the bow. Took on about 1/2 gallon in 4 hours. Not much on a 1648. When I went with my friend it took on no water because it lifted the bow up a bit with the added wieght on the back.
I did learn that I will need to lower and widen my trailer bunks. Tin sits to high, had to bring my rear truck tires to the water edge to load boat.
CrewCabMax
Post by CrewCabMax »
Did you have to thin the parkers paint to spay it? If so, what did you use and how much? Thanks!!
Howard
Post by Howard »
Yes, about 10 to 15% and I used paint thinner. Been working on lowering the bunks. As you can see in the pic's it sit's too high. Don't know how the previous owner managed like it is now.
Nevillizer
Post by Nevillizer »
Looking real good.
Well behaved people rarely make history!
Troutman3000
Post by Troutman3000 »
What did you use to patch the holes? That boat looks great btw!
weezer71
Post by weezer71 »
WOW :shock: Looks brand spankin' new! Great job!!!
Scott P.
Andrews, IN
(weezer71)
10' SeaMaid Flat Bottom Mod (Updated 7/18/10 - Finished)
http://www.tinboats.net/forum/viewtopic ... 21&t=14475
Teammuir1
Post by Teammuir1 »
GREAT JOB and nice looking boat...
I have a 1648 alumacraft ....... mine on the other hand is much older...
STILL in great condition.. just older.....
SO I AM CURIOUS on the nose of your boat.. you replaced some aluminum...
would you please tell me what size you bought ? were you bought it? and how
much was it....
I cant really tell in the picture... as to the size... I am assuming is a piece of Round
aluminum tubing?
thanks so much...
Howard
Post by Howard »
Stacy Warner
Parts/Accessories & Warranty
Warner's Dock, Inc
1020 N Knowles Ave
New Richmond WI 54017
888/222-3625
https://www.warnersdock.com
I'm thinking it was $30 for a 6 foot piece and $30 to ship. They bought it from Alumacraft and had it shipped direct to me. For me, it was worth every penny since it changed the look of my tin to a much cleaner look. It was a big concern when I bought the boat but was a easy fix.
Oh yea, measure your top rail and send a pic to Stacy with your HIN so Alumacraft can match it with your tin.
DuraCraft
Post by DuraCraft »
Howard, I am late to the party, just found this site, but, want to ad my congratulations too! Man, you did a great job!
Coffee and water mix real good...
I ain't the slickest eel in the crick.
I like >))))))):> Ummm good.
You are = you're, i.e., You're doing a good job.
Your = possessive, i.e., That is your boat.
"I thought I was wrong one time, but I was mistaken". Command Sargeant Major J.D.
Howard
Post by Howard »
It has been a year since my last update, not that anyone cares :) but what the heck, here some pics go
Howard
Post by Howard »
More pics, still have some more mods to do but I am very comfortable right now
Had to cut transom to lower for a short shaft. Capped off my cut with the bottom expander from a storm door, perfect fit and its aluminum
fish2keel
Post by fish2keel »
Great mods! Quick questions did you rivet in your cap on your transom or weld it? Mine is cut from the previous owner in a rectangle and im wanting it to be more like yours to give my tiller more clearance.
Thanks and great job!
Force from Above!
Howard
Post by Howard »
I would have prefered to weld it but I did rivet it and it holds up fine. I have since added a 5/8 board to the inside to accommodate the throat of my 15HP
