It is currently 19 Feb 2019, 19:11
 Page 1 of 3 [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: Lund wc14 conversion
PostPosted: 02 Apr 2018, 21:57
Hey all
Man this site is addicting. Thanks to all who have contributed.
This is my second boat. I upgraded at the end of last year from my two man plastic boat. I've only had her out on the water once last year before I put her away for the winter. The boat is a 2012 Lund wc14 with a 2016 20 HP Yamaha 4 stroke. The length of the boat is 14.5 ft with a beam of 69". I noticed the transom braces were cracked so I plan on getting them welded. Other than that the boat is in great shape.
On to the conversion. The plan is to have a casting deck that is extended to the first rib. A flat floor with a rod locker on one side and storage on the other. And a rear casting deck at the back. I'll be using aluminum angle and sheet. I'll be covering the decks with marine vinyl.
One question that I have is how to support the front of the front deck. There aren't any rib at the bow of the boat and there isn't a small seat at the front either. I'm planning on adding a cap for my bow mounted trolling motor. So I was think I could hang it from there and add some extra support.
If you have any questions or comments it would be appreciated.
Thanks
https://www.tinboats.net/forum/viewtopi ... 21&t=44712
PostPosted: 02 Apr 2018, 23:02
That'll be nice. Probably have to rivet angle along the sides to support the front deck frame.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
PostPosted: 03 Apr 2018, 09:10
I know it might not be very happy news to point it out, but do you see the bow in that transom ? Put a straight edge along the back and see how curved it is. That's supposed to be dead straight. If it's not you probably have rotten wood. (Even if the screws still bite). Transom supports don't just crack on their own...
PostPosted: 03 Apr 2018, 09:37
wow yea, something is definitely wrong along the transom there (hopefully its just camera distortion or something). I know those new 4 strokes can be quite heavy, maybe that combined with a rotted transom led to that sever bend in the rear.
On the front deck - yea it seems if you have no supports the solution is to use rivets through the hull to add in some angle on the sidewalls.
1967 Lund S-16, work in progress!
PostPosted: 03 Apr 2018, 18:28
I am also concerned about the bend or lack of flatness in the transom. I ended up taking off the caps on the weekend to take a closer look. The corners seemed a bit wet everything else was dry. I took a screw driver to it and not much happened. What do you think? Should I replace the transom first? I may regret saying this but it looks like a fairly straightforward job. All bolted connections.
PostPosted: 03 Apr 2018, 20:21
The motor weights about 120 lbs. There actually is a tag that says the transom was designed to hold a max weight of 230 lbs.
I'm try to avoid riveting through the hull. If it's the only way would I need solid rivets or just closed pop rivets with 3m 5200?
PostPosted: 03 Apr 2018, 20:52
You don't want to do a bunch of expensive work on a hull that's not 100%. For me it would constantly be an irritation worrying about it .... It could be totally rotten in the middle.. That curve and the broken support means something isn't right. I'd do that along with fixing the brace... then you'll be able to do the rest of the work with total confidence.
PostPosted: 04 Apr 2018, 07:43
I agree, better to fix the bones first then worry about cosmetics.
You would probably be fine with closed end all aluminum pop rivets with epoxy, since you should be a bit above the water line, however i think most folks on here will encourage you to go with traditional rivets. Being as these will be supporting your whole deck and have some force on them, I would be inclined to agree to maximize your strength, etc. Additionally, since you would have very easy access to do these rivets, it would be pretty straightforward. Check out the youtube videos on the subject. You can do em by hand, or use a $10 air hammer with flattened tip and a chunk of steel.
PostPosted: 04 Apr 2018, 10:41
Yea that bend coupled with the broken support leads me to believe some impact damage may have occurred somewhere - maybe the PO hit something caused some internal damage, or maybe he backed the motor into something when trailering or something which torqued on the transom. Either way I would fix it now and be done with it.
PostPosted: 04 Apr 2018, 20:57
I appreciate the advice guys. I think you're right I should fix the transom before moving forward with the conversion. I guess I'll know what to look for if I ever buy another boat.
I've done some reading on transom replacements. Should I be ok with acx or do I need to go with marine plywood? I've seen others use two 3/4" sheets glued together with tight bond and then three coats of spar urathane.
Let me know if I'm on the right track.
Thanks
PostPosted: 04 Apr 2018, 22:04
Any X grade plywood will work fine. The beauty of doing it now is that you’ll be prepared to replace it easily next time. No reason to get too obsessed about making it “last forever”.
That's a good philosophy to take into the rest of your build too. It's much more important to design every part of the system to be easily maintained and replaced than it is to try to use stuff that's supposed to last forever...
You can see that even on an expensive boat like that, parts don't last forever... Mother Nature hates forever...
PostPosted: 05 Apr 2018, 07:35
On a previous deck i made i used the west system epoxy and resin to "waterproof". Really really good system, but expensive. I just finished my deck on my current project, and this time i was doing it on the cheap.
Before putting on straight spar, trying doing the first few coats with the spar-boiled linseed-mineral spirits mix. I think the ratio i used was 1:1:2. you basically keep applying til it puddles on the wood. This allows it to really soak deep into the wood and help seal. After that dried, then i put a coat of straight spar on the outside. Maybe im imagining things (this was the only time ive ever done it this way), but it soaked up a ton of this mix, and Im all for having interior protection on the wood and not just on the surface.
PostPosted: 06 Apr 2018, 16:34
Well the transom is out. Pretty easy to do it took about an hour. Lund made it easy with bolted connections almost like they knew it would fail.
The wood is a bit rotten but no real soft spots. I did notice that the wood is very warped. I'd say about 3/4".
Let me know if more experienced eyes see anything I missed.
Thanks
PostPosted: 06 Apr 2018, 23:20
Nice glad it went easy. Maybe ya just got a lemon, someone installed some transom wood before it dried completely and you just got unlucky with some major warpage
PostPosted: 13 Apr 2018, 18:43
Time for an update on this project.
I started working on the new transom last week. I'm using 5/8" Acx plywood bonded with almer probond max. I tried to find titebond 3 but its hard to find in Canada. The almer glue has the same waterproof rating so I'm sure it will be fine.
The transom thickness turned out to be 1.25". I have it cut to size now and have drilled all the holes. I'm treating it with old timers formula then it's on to the spar urathane.
I decided to continue on with the framing while I wait for the spar to dry. I'm going to be using a mix of 1.5 x .125" and 1 x .125" aluminum 6061-t6. The floor will be .090" 5052 aluminum.
I'm planning to start cutting out the middle bench this weekend. I'm going to use a sawzall with a bimetal blade. I'll be adding support back to stiffen the walls.
Users browsing this forum: Extreme and 82 guests
mud-skipper
