A 40lb or a 55lb would be ideal.. you can get by with a 30lb, but the bigger the motor is, the longer the battery will last because your giving it less " throttle". Minn Kota is probably the best brand out there, stay away from the off brands like Shakespeare ( you can't get parts for those if they break down)xforce said:what size electric would you recommend ?
