It is currently 26 Mar 2019, 13:16
Wired2fish
 Page 5 of 5 [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Check Engine Light
PostPosted: 21 Dec 2018, 21:08
My GF has a Toyota the would lock up the ignition (every time) trying to start it after she hit the parking space bumper on her last park. The "mechanic" told her it's a problem with Corollas and told her to not hit the bumper in the parking lot.
The cause was the remote control battery power was strong enough to unlock the doors but not to disarm the security system. I replaced the battery in the remote nearly 2 years ago and it never happened again.
Regards,
Gary (in South Florida)
PostPosted: 23 Feb 2019, 11:36
Two weeks ago I had that same error code 0440 on my 2003 Trailblazer.
Replaced - fuel tank
- fuel pump/sending unit
- purge valve
- fuel lines
- fuel filter
- gas cap
- air filter
That problem solved.
Now the transmission down shifts and up shifts when driving at a constant speed. Speed up or slow down the transmission is fine. Thinking maybe the transmission solenoids are failing
If I had not just bought this Trailblazer in November I would have junked it.
I have to learn that I cannot afford to buy cheap priced vehicles.
PostPosted: 24 Feb 2019, 00:05
Update, My car still throws this code as I pass through that location. It is going on two years now. I guess I will have to live with it. I only pass through there once a week at the most so it is not too bad. Other than that the car is in excellent shape. It only has 85,000 miles on it. I have taken it on vacations and driven it a thousand miles and no code. As I mentioned in an earlier post I had it tested and they found no problem with the EVAP system. I am thinking it may be electrical interference from something there.
PostPosted: 24 Feb 2019, 06:31
August 2017:
New River Rat wrote:
I've read this thread and would almost bet that there is some form of electrical interference
February 2019:
Makes perfect sense to me. :wink:
My Tinny is a tool, a means to an end, if you will.
New River Smallies
Case Plastics Pro Staff
Users browsing this forum: No registered users and 3 guests
FishonFabrications
