What steel screws and brackets do to aluminum
knifer
After gutting rotten interior discovered what iron brackets and screws do to aluminum ribs. Shiny due to wire cleaning.
olefart said:
question, would the aluminum brazing rods work to fix this corrosion?
I think that they would.
FYI, just had a similar effect on a friend's boat and we cleaned the area, washed w/ vinegar, dried, primed w/ self-etching zinc chromate rattle can spray paint, and then topped with G-Flex flexible epoxy. As good as new (within reason). Epoxy products need to be painted to protect them from UV exposure.
The issue with the brazing rods is if you over heat the aluminum you will cause more damage to the rib.
If you want to use the brazing rods do a lot of practice on scrap aluminum long before you take a torch to your boat.
pbw said:
What is the hives recommendation on type of screws?
Uhhhhh ... tin boats ... don't use a screw if you can use an aluminum solid rivet (preference) or closed-end blind or 'pop' rivet (second ... provided the strength/shear requirements are achieved).
If not, through-bolting is your best strength, but INSULATE the SS fastener from the aluminum by using Tef-Gel seal or putting adhesive-lined heatshrink on the body of the bolt and nylon or other non-metallic washers under the head and nut of the fastener.
To do so otherwise it to create an environment for galvanic corrosion where the more noble stainless steel will cause an electrolytic reaction with the tin boat ... to where it will corrode away. This reaction is worse on saltwater boats as saltwater is an ideal electrolyte!
What people said above - but give it an acid wash, then neutralize with ammonia / baking soda if you intend to prime / paint.
I don't think any aluminum "brazing" is structural. You need to weld, preferably TIG if you need a structural repair
