Remote Controls for Mercury Outboard???
Freenchy123
I recently bought a 1992 Mercury 20HP, 2-stroke outboard. The S/N on the motor is "0D147984" and when I do a search is comes up with the model number "1020201MD". I'm wanting to install remote throttle control; however, I'm unsure of the control system that is needed to fit this motor. From searching the past week, I believe I'm going to need a 'Quicksilver commander 2000'; however, I'm unsure of the series for this motor.
Any help would be greatly appreciated.
Thanks,
Dan
I put a 1994 Mercury 60/45 jet in my boat and bought some used controls off Ebay since I wasn't sure what I needed. I think you will need the Gen I style control cables but you should look at your motor to see what the connections look like. It's tough to tell from reading, but it looks like 92 to 93 might be a changeover for some Mercury stuff so you might need to research a little deeper to make sure you get the right parts before spending too much money. Here's a link to the style controls I'm using. The side mount can be switched from one side to the other so don't let that throw you off.
https://www.ebay.com/itm/For-Mercury-8Pin-Outboard-Boat-Side-Mount-Remote-Control-Box-Cable-15ft-Solid/173339910204?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20131003132420%26meid%3D85b0dcfca36f46d2adb0d1a341e5d5a9%26pid%3D100005%26rk%3D5%26rkt%3D12%26sd%3D263983803065%26itm%3D173339910204&_trksid=p2047675.c100005.m1851
