Shear Pins
1960 yellowboat
Homosassa Florida
I have a Vintage {AKA} old outboard that uses shear pins.
Whats the opinion here?
Brass or Aluminum?
Gonna make my own out of round stock.
I carry two extra props and an extra prop nut but need some pins
I guess if nobody has an answer, I'll put in my 2 cents worth. I'm sure no expert but I know that brass and aluminum react galvanically, as in the brass will corrode the aluminum. Also I have an ancient Johnson that uses shear pins and still have some of the originals. They are not aluminum but the prop is. Thus I'd say go with what your prop is. Regards, Woody
I see I need to correct this..the shear pins are not brass and the prop is aluminum.
