Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
New mercury 40hp
Tracker grizzly tiller
Have a question about your motor? All motor talk and questions go here.
turbotodd
New mercury 40hp
Post by turbotodd »
y'all outta come out to stuttgart and watch the duck hunters.
15' boats with 70, 80, 90hp outboards, almost all tiller steered. They spend more on the motors than I did on both of my cars combined! Mods?? Mod a 70 to make 130hp...seen it quite a few times and they scream. But for me, 30mph is fine (25hp). There's only been twice (that I can think of) I needed to go faster and once was in a boat race with a guy who had exactly the same boat with a 40. The other, outrunning the weather. We still got drenched but it was mid summer and before the shower, about 105° actual air temp so the rain felt nice.
Weldorthemagnificent
2
Re: New mercury 40hp
Post by Weldorthemagnificent »
Special kind of crazy in Arkansas. I've seen some of that over by crosset on the oachita.
nccatfisher
6
New mercury 40hp
Post by nccatfisher »
I have the same boat and it wanted to porpoise bad when my motor set in the stock position. I added tilt and trim and it was aftermarket thus it has a 5” back set and it stopped it.
But I also have two batteries up under the front deck and made a fuel tank that goes all the way across behind it that holds 10 gallons.
Johnsk
New mercury 40hp
Post by Johnsk »
It s 2018 1648 grizzly till bought it with 25hp it was a dog cruise was 17ish I have 2 Amy batteries 1 in stern and one in how 2 guys and gear 460 and the boat weighs 590 max hp for boat is 40hp so that’s what I upgraded too. Much happier with performance can cruise 26-27 mph 4800 rpm I will be moving second battery to the bow , battery weighs 65lbs so that a little more than the 40 lbs diff in the 25-40 hp Merc thanks for replies.
CedarRiverScooter
5
New mercury 40hp
Post by CedarRiverScooter »
It is just plain fun to skim along at 30+mph on smooth narrow river - Don't need any other justification!
Riverdog
4
Post by Riverdog »
Trim down
Shift weight
slow down
I guaranty one of those will work. :D
2013 1752 Blazer SS Mercury 60/40
Jump aboard, let's take a ride. <-clicky
Johnsk
Post by Johnsk »
Any recommendations on gauge wire when moving start battery up front I’m thinking 2-4 gauge it’s 12 ft run
Johnsk
Post by Johnsk »
GYPSY400
Post by GYPSY400 »
Johnsk wrote:Any recommendations on gauge wire when moving start battery up front I’m thinking 2-4 gauge it’s 12 ft run
Probably 4ga would do it.. I usually buy a set of booster cables and cut the ends off.. if you get a decent set on sale it's cheaper than buying the wire individually.
Sent from my SM-G903W using Tapatalk
nccatfisher
6
New mercury 40hp
GYPSY400 wrote:
09 Dec 2019, 13:19
Yep, that is what I did.
LDUBS
3
Post by LDUBS »
OK, I guess this is total hearsay. I read somewhere (probably on TB.net) to be careful about converting jumper cables to permanent use. The issue is that some use copper covered aluminum conductors and are only intended for momentary loads. As my kids might say, sorry to be a buzz kill.
Have Rod - Will Fish
2
I've used jumper cables for years. Starting a small outboard is a small momentary load, smaller than any car. And the charging current is low. Might be different on a larger motor.
LDUBS
3
New mercury 40hp
Post by LDUBS »
Weldorthemagnificent wrote:
09 Dec 2019, 22:19
Thanks Weldor. My memory was bad. What I thought I remembered turned out to be a caution about using cheap jumper cables for continuous duty on a trolling motor. I guess the cheap ones can get hot and melt away the thin plastic insulation. Anyway, sorry guys for the incorrect info.
2
It's something to keep in mind. A bad connection can cause heat as well. A couple boats ago I used jumper cable wire to run a bow trolling motor with the battery at the back. It worked fine but it was only a 30lb thrust 12v motor. I imagine once you get into higher thrust motors you'd better spend a little more on booster cables. I usually look at the size wire coming from the factory on either trolling motor or outboard and let that be my guide for minimum size.
Johnsk
Post by Johnsk »
