TOWING BOAT TRAILOR WITH FRONT WHEEL VEHICLE
EMORY7568
Looking for input on towing a aluminum boat with trailor with 20hp with a gmc terrain 2.4 with front wheel drive. will I run into issues with a a front wheel drive?
**** NEW INFO **** BOAT /TRIAOR INFO SAYS 1400LBS WICH ID BE SURPRISED IF ITS THAT HEAVY, ITS A 16 FT ALUMICRAFT WITH A STEERING CONSOLE AND FRONT AND BACK DECK WITH A 20HP MERC....MY ETERRAIN SAYS 1500 TOW CAP.....RAMPS I GO ON ARE CONCRETE AND VERY FEW ARE GRAVEL ....
Possibly on steep ramps, but a lot of people do it. Weight transfer is working against you with FWD.
As long as you have access to decent paved ramps that aren't too steep, I think you'll be fine.
Won't be a problem with a lightweight tin boat.
If the boat/trailer weighed more than 3500# I would be concerned.
That said, I towed/launched/pulled out our 3500# Ski Nautique with FWD Ford Flex once (truck was in shop), steep ramp, no problems but I was nervous.
I use my 5spd Camry to pull my little 1436 around without any issues - though the launches I've used have all been well sloped and paved.
I'll add this, if you live in a hilly area you'll want some momentum going up a steep hill if it is raining out.
I had a little Chevy Cavalier back in the 80's was towing a package that was under 1000 pounds, going up this hill I was fine until the road narrowed and the lady coming down the hill creped to a crawl and I had to come to a full stop behind her. I literally started sliding backwards on the hill when I took my foot off the brake.
Scary **** right there let me tell you, somehow I got traction and took a side street to the next hill and made the turn up with momentum again.
When I said I could tow it with my camry I meant that I could do it safely...on any roadway.
