red95gtcoupe
- Joined
- Feb 20, 2011
- Messages
- 23
- Reaction score
- 0
I recently purchased an 88 bass tracker and have been going through and cleaning up some of the wiring. As of now, everything works except the flasher (Eagle in-dash 1) and auto aerator. The flasher will power up if the power and ground are hooked directly to power and ground, but not when switched. The aerator works in the manual position, but not auto. Both switches appear to be wired together into a round black cylinder under the dash (relay?) It is a sealed black unit a couple inches long and maybe an inch and half in diameter. Also, the timer switch only has two of the three hookups wired to anything. Shouldn't it have a ground, power and out? I have attached a (crappy) diagram i drew in paint since trying to describe the diagram would be wordy and confusing. Can I just wire the aerator to the timer, and the flasher switch just to the normal ground? Or should I eliminate the flasher switch ground going to the cylinder if it is a relay? Sorry if this is confusing.
Brian
Brian
