Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
Does anyone use lights on 12v batteries?
If Bowfishing is not your cup of tea, DO NOT ENTER! This section is for questions and reports
TNtroller
Post by TNtroller »
most smaller boats use the cranking battery for the power supply for lights. What lights are you talking about? Nav lights, anchor lights, cockpit lights for nighttime fishing?? Need some more info so someone can point you in the right direction.
TNtroller
Post by TNtroller »
just use any 12v source you have, whether it be the TM or cranking battery. LED lights will not drain the battery as quickly, depending on the distance you may have to travel to your fishing spots.
billhowardoutdoors
6
Post by billhowardoutdoors »
The boat I am modifying now will run off 12v. I'm trying to design it where the lights can go underwater since I will run lower lumens with the LED's than other types of lighting. By going underwater, I can eliminate the reflected light off the surface of the water. Think flounder gigging.
PSG-1
Post by PSG-1 »
Here's my setup for gigging:
https://www.tinboats.net/forum/viewtopic ... 5&p=231163
Also supplementing these lights, are a set of Aqua signal docking lights mounted in the prow of my boat. They use MR16 LED's, which have the same intensity as a 55W halogen, with a fraction of the current draw.
ALUMA-JET project:
http://www.tinboats.net/forum/viewtopic ... 21&t=22023
Fishing, jet skiing, target shooting, jet-boating, and even a little oyster harvesting with Larry The Cable Guy.
Watch it all right here:
http://www.youtube.com/user/HKPSG1Shooter?feature=mhee
Paul Marx
6
Post by Paul Marx »
I'm ordering 1 20" and 2 6" of these . Plashlights.com
"I'll be okay , it only hurts when I breathe "
BDS05
6
Post by BDS05 »
Get two extra batteries and a handful of LEDs.
