Couple donor ski questions
Deezil
There is a CL ad near me that has a couple skis, Id like to make a 14-16' probably V hull frankenjon..
There is a 1995 Seado XP that he thinks maybe has a fuel issue, and he also has a 1993 yamaha wave runner, it runs perfect.
Thoughts? Wants $775 for the pair, but have not talked to him about one or the other yet.
These good ones? Or should I look for something else?
What is your budget?
Keep in mind buying the donor ski is just the tip of the iceberg in cost.
If you can afford it, a yammie 4 stroke ski can be bought for about $2500. Definitely best in class for all factors.
The yamaha brand has best reputation & parts are very easy to get.
Do a compression test & a crankcase leak test if they will let you. Also make sure it has spark. You can spend over $500 on a engine rebuild. Also look up the tunnel past grate & see if impeller is not beat up. Pump can be several more hundred to rebuild. I spent $150 just on carb kits. You get the picture.
budget is as little as possible, if its going to cost $2500 I wont do it.
Thanks
two pumps.....
two motors.....
two ecu.......
for 775$
man id jump on that like a fat kid on cake!!
