D duckman11 Active member Joined Oct 9, 2017 Messages 25 Reaction score 0 Jan 12, 2018 #1 what would yall recommend to patch a jon boat hull? is there a huge advantage of using 6061 over 5052? all repairs will be welded fyi
C CedarRiverScooter Well-known member Joined Nov 13, 2014 Messages 1,522 Reaction score 5 Jan 13, 2018 #2 I would use the alloy that is easiest to weld. Unless you have a very large section, the yield strength shouldn't be a big factor.
D duckman11 Active member Joined Oct 9, 2017 Messages 25 Reaction score 0 Jan 15, 2018 #3 kinda what I was thinking. we use 5052 to make our class 8 fuel tanks here at work so I figured 5052 would weld just fine
S Samsdad1 Member Joined Oct 26, 2017 Messages 22 Reaction score 0 Jan 16, 2018 #4 Also depends on if you are bending the material? Some Aluminum is not great for this...
D duckman11 Active member Joined Oct 9, 2017 Messages 25 Reaction score 0 Jan 16, 2018 #5 yes it will be bent....a lot! im thinking 5052 might be the better alloy
Lil' Blue Rude Well-known member Joined Jan 12, 2011 Messages 754 Reaction score 1 Location SE, Mo Jan 16, 2018 #6 I'd use the 5052. Pretty sure that's what some boat builders use. 5052 will bend more then 6061 before breaking.
