16/48 Tracker w/ 145 HP
SC Designs
Alright guys, time to start another one. I sold my other Jetjon so its time to upgrade. I picked up a 2000 Kawasaki Ultra 150 that has the 1200cc 145hp motor and a 95 16/48 tracker. It's tear down mode for the next couple of weekends. The tracker is completely rotted on the inside, so its all got to come out, the hull is in good shape though. Going to try and make haste on this project being I am without a running boat right now. Updates will follow.
Ok, some progress updates. The boat has been gutted and the ski hull has been mated and sealed in. Bottom paint has been applied and the polling platform has been completed. The transom was rotted and needed much repair. There were a few leaks on the bottom that needed tending to. Overall it is going pretty smoothly. Last night I got the sides and transom prepped for paint. I will be putting Durabak Smooth Dark Gray on the sides and transom. Hopefully by the weekend I will have the engine mounted in and I can start on the inner structures and decks. Really looking forward to this thing being in the water. It should be a rocket with this engine.
Here are some pics of the cleaned out boat and cut up ski hull.
Quick update, I got the paint on and the motor mounted in this past weekend, now time for the decking.
This set up is my dream boat. My buddy has a Yamaha XLT 1200 I'm trying to buy so I can do the same thing to my Grumman 1649! Really excited to see the outcome of this build!
Thanks man. I'm really excited too. It's getting close, hopefully by Sunday I will be 90% done. Can't wait to see how this much horsepower pushes this thing.
Here is the update from this past weekend. I got 90% of the decking completed, all that is left is the decking in the front. Console is built with everything wired up. Still have to make the side panels and a engine cover but other than that she is just about ready for the water. I arranged the seating so that when I am riding solo I can sit in the middle and steer with my right hand and when two people are on board I can move the seats to the out side pins and then I would steer with my left hand. I should have it all wrapped up over the next couple of days and hope to be on the water this coming weekend.
Here is a video of it running last night.
https://www.youtube.com/watch?v=5OKUyx1gSeM
Well, I can say that it is a completed project aside from putting the platform on top of the tower. I brought home the tracker on Sept. 15th in rough shape and one month later it has come full circle. She runs out great. I have not stretched her out yet because I am trying to break in the new top end on the motor but she cruises happily between 37 and 42 mph. I'm thinking she will touch 50mph once it is all said and done with. I have a short video of her running that I will post later.
That came out amazing! Can't wait to see the vid of it running! Color scheme is very sleek also.
Here is a 30 sec. video of it cruising around 37 mph.
https://www.youtube.com/watch?v=WJKM2Bj_nG0
badrider77 said:
That is some beautiful work! Great job!!
Thanks man, I seconded what CedarRiverScooter said in his last post. You want to try and make the transition from the jon boat hull to the ski hull as smooth as possible. I try and leave about 10 to 12 inches of the actual ski hull in front of the pump exposed so that the transition happens far enough in front of the pump that it will not cause any disruption of water flow plus I add bondo and fiberglass and sand the hell out of it to make it smooth. I think if you fill that step in with bondo and smooth it all down it will cut out most of the cavitation.
Sorry, missed this story until now. Kudos on the speed build!
You're gonna get asked about it at every boat ramp you go to.
The adjustable seating is a great idea, as well as the fwd fuel tank.
How much gas do you burn per hour? I am running about 7 gals per hour (750CC) but keep the hammer most of the way down.
Hey guys, here's a little update on the performance. Everything is running great, she seems to be the most happy cruising 35 mph. and at that speed the motor doesn't seem to be working hard at all. I am a little disappointed in the top speed though. Right at 46 is all she will pull. I feel there is a lot of drag on the hull. I used a roll on bed liner that has a really rough surface. I was more concerned with sealing rivets than speed. I bet if I had put something like Gator Glide on there it would be a little faster but its fast enough. As far as fuel burn, I haven't really run it enough to get an accurate number. I'm still in the break in stage with the new top end on the motor. Attached below is a pic of all three Jon's that I have built in the past year. This was from last weekend.
They keep getting bigger! Are you going to sell the older one's? Just wondering how hard they are to sell.
46 MPH seems pretty fast in a 16 ft jon boat.
I was out yesterday, probably doing 30, when a strong wind gust changed my course. I think 50+ mph would be risky for getting air under the boat at the wrong time.
