First Jon Boat - Budget Conversion
- weaselbob74
- Contact:
Hi. I'm a new member, just bought my first Jon Boat (Well me and my buddy went in on it, for a fun project). I have had jet ski's, but never a boat.
I have been following this site for a little while and picking up some ideas for our mod.
We bought a beat up Sears Gamefisher 1436, with a 36 Lb Trolling, and a 9.9hp Johnson. It came with a trailer, I believe it is a tilt trailer.
9.9hp Johnson
34 lbs. Trolling Motor
9.9hp Johnson
Welcome to the site!
That boat looks like it will be a fun project for you and your buddy. Make sure to post lots of pics.
2000 Bass Tracker Pro Team 165
40hp Mercury outboard
55lb thrust Motorguide trolling motor
2000 Trailstar Trailer
- weaselbob74
- Contact:
We just started working on it this past weekend. We spent some time planning it out. And we started sanding and Priming and Painting. I will post some pictures.
We decided to build a deck on the front, with a seat. And three storage compartments. 1 for our tackle boxes and such, one for 2 batteries, and a Livewell. In the back we are going to build a small deck to cover up the area between the transom and the rear seat. That is going to house our Gas tank, paddles, and Life Jackets. And in the center we are going to build a floor right on the ribs with most likely 5/8 plywood. I bought a welder since we have a few minor repair to do, but I think we are still going to stick with wood, over aluminum.
9.9hp Johnson
9.9hp Johnson
Possibly turn your livewell and battery compartments 90*. Otherwise when your running with an empty livewell you will be heavy on one side.
LEFT is right! The reel handle is properly oriented when it is on the left side.
- weaselbob74
- Contact:
I completely agree. We had planned them to go the other way, but we didn't have enough room. But I think your right, we have to figure out a better place for that.danmyersmn wrote:Possibly turn your livewell and battery compartments 90*. Otherwise when your running with an empty livewell you will be heavy on one side.
9.9hp Johnson
9.9hp Johnson
- weaselbob74
- Contact:
We took out the center seat to allow more lower floor space. Hopefully this will lower the center of gravity.
9.9hp Johnson
9.9hp Johnson
- huntinfool
- weaselbob74
- Contact:
Thanks. Now I just need to add 18" to my widthhuntinfool wrote:Looking good keep 'em coming.
9.9hp Johnson
9.9hp Johnson
oh no problem, we have a build like that already. Just do what he did.
- weaselbob74
- Contact:
We sanded and primed the boat.
We added a red stripe.
I added the fiberglass the external transom board (don't know exactly what its called).
9.9hp Johnson
9.9hp Johnson
Are you going to have it on the water this year?
- weaselbob74
- Contact:
No I don't think I'm going to have it done by then. I wish I did. right now I'm at a stand still because I'm waiting for my welder to come in for eBay. There are three cracks on the top part. And a couple holes to fill before I can paint the top section.
9.9hp Johnson
9.9hp Johnson
- weaselbob74
- Contact:
Here are some pictures of painting the bottom and the motor cover.
9.9hp Johnson
9.9hp Johnson
Welcome aboard guys.....JIGGY,,,That is gonna be Sweet when ya getter done......
- weaselbob74
- Contact:
Thanks Jiggy.jigster60 wrote:Welcome aboard guys.....JIGGY
9.9hp Johnson
9.9hp Johnson
