Convert clamp-on troller to Folding bow-mount?
DownSouthGaBoy
Central GA
Quick topic for discussion...
Has anyone ever seen a homemade folding bracket for a trolling motor to convert a clamp on style to a bow mount? I googled it but it only comes up with how to mount them. I've already got a clamp on troller, but like the convenience of the ones that fold up on the deck. I know Motorguide makes their Gator Mounts, but have better things to drop a few hundred bucks on (like carpet, paint, etc...).
If anyone knows of anything let me know. I am going to plan something out and if anyone has any suggestions or ideas, I would appreciate the help. I'll make sure to take plenty of photos on the way.
I have never seen a homemade folding mount; I would think it would be pretty difficult to build and keep working. I found mine on Crqaigslist for $20.
Here is one like mine:
Bow Mount for motor
a member here posted his a long time ago will try and find it for you
If memory serves me right it was BassnBob
https://www.tinboats.net/forum/viewtopic.php?f=3&t=11366&p=115835#p115835
hope this helps.
Thanks for the info, it does help alot. I'll probably use some of his idea and see if I can modify it a little to make it a bit more... err... aesthetically pleasing.
Again, when I'm in construction phase, I'll keep it posted. If anyone has anymore ideas or photos let me know...
I believe a trolling motor is the most important piece of equipment on the boat if you bass fish.
I have a 65# Minn Kota Maxxum 24v foot control on my 15' boat. I can fish and control the boat in high winds or jump from spot to spot quickly.
That homemade mount that BassnBob made is nice but its not comprable to a real bow mount that all you have to do is grab a rope and flip the trolling motor out and then steer with your foot.
Check craigslist and the classifieds section in your local bass fishing websites for a used one.
hope this helps.
That is a pretty sweet homebrew mount I must say...
Going to post an image here for posterity so the link and images are on th same page.
file.php
file.php
I made one for my buddys tri hull useing some 2x4's and some hinges, It was cheap and functional. I will try and get some pictures of it for you. The only issue is you must get and extension handle to use it.
I simply used a 3" x 4" piece of aluminum angle I bought at Metal Supermarket. Cost me $3 and really seams solid.
Ok here's my solution to the problem. I do like the simple fixes everyone else had, however, I do not like the extra bulk of the clamp on attatchment, so I eliminated it.
Here is what I did (brief explanation in captions)
First I removed the pin that holds the clamp to the shaft...
Next I had to remove the spring loaded piece for clearance...
Next I made the folding arm and the mounting bracket.
I didn't get into any specifics with mesurement on the arm, I kinda used trial and error. I found the arm should be half the length of the distance from the top of the sliding (top) bracket (with the motor in the folded position) to the top of the pivot (bottom) bracket with the motor in the deployed position.
But first came the mounting bracket.
These are the final mock up close-ups. Let me know what ya'll think.
Hey I'm no metal worker myself, I had the drill and grinder already, and I borrowed someone else's metal chop saw to cut everything, It took more thought than effort really.
I built a mount like that for my boats first incarnation. I removed the factory mount from the transom style motor and built one from wood and aluminum angle. What I was trying to do was copy the mounts I had seen on bow troll motors. It worked, but was a pain to use. I'll be using the same motor this time, but with a much simpler homemade mount. I don't have any pics of it, dang it. If I were doing it again, I'd keep the factory mount and design around it.Looks to me like you got the simple part figured out ,though, please post how well it works for you. By the way, my motor is a Sears DieHard. Minnkota made them for Sears. Darn good motor, took everything I threw at it for 15 years. I'll be reusing it on this build.
