Grumman 1649 Jon Boat
sixshootertexan
Magnolia, Texas
I picked up a used 16' jon boat back in the spring time. Here is the boat as we got it (with my happen son)and after a quick clean up and paint job to the exterior. Had to do a little fishing before I started a total rebuild. I will be posting the progress as it goes.
Here's what it looks like after I stripped everything off it.
Trailer after cleaning and painting. Still got a lot to do to the trailer yet. Going to build guide posts and boards. Reinstall the front support and cat walk. 2 new tires and bearing buddy's. All new lights and wiring.
Looks great. If you haven't done so yet, you may consider setting up your bunks to catch the transom. Doesn't look like they would need to move far.
Put the boat back on the trailer to get it ready for some welding.
Removing the old jack plate.
OK it's not pretty under all the pieces of aluminum that was on the back.
Got the transom cover off today and all the rotten wood is gone. Time to get some aluminum and start welding.
I took a day off work today and got some work done to the transom. Cut out the rotten stuff and fitted a new piece in. Need to clean the areas that are going to be welded and it will be ready to weld.
You know it's funny, before I started my own project I looked at these forums and I felt like everyone was slacking. Over a week period they would post tons of pictures and it never really looked like they got much done. Then I started my build, and simply cutting 6 2x4's to fit the bottom of the boat took a few hours. Really started to appreciate what most people on this forum can do. :mrgreen:
Trailer looks great! Can I send you mine?? [-o<
Lookin forward to seein you build this one!!
I haven't had much time to work on it. I have been working 50+ hours a week along with all the other things we do. Going to San Antonio tomorrow for a rc drag race.
Wow I finally got a day off when it wasn't freezing or raining. This weather has been wild. I was able to get the welder out and make some new guides and got a little painting done on the inside.
Finished the paint on the inside. Took the boat back off the trailer and flipped it over. Ready to order my Steelflex now.
