Need Input from the jet Jon gurus
CTilton
I found a very nice 2010 Grizzly 1648 , I have a late 90's Seadoo 787 and pump to mate to it. I have fab skills and access to equipment to build it and would love to not use the seadoo belly but stay with all aluminum. I know you have to build a spoon to make the water flow properly, just want the "what is the best route" consensus. I plan to eliminate the rt side steering console and go the center stick steer to increase the size of the casting deck. I spent my fishing tournament life in Basscats and then in Xpress's becoming more and more a backwater and river guy. I opened a business 3 years ago, so my bass fishing stopped but things are loosening up enough I can start fishing again. I will run a Fortrex 80 on it so I can use two batteries and will crank off one of the trollers. I can put the fuel tank and batteries anywhere for balance. Any input would be appreciated!
Chris
I am not a guru but visit Tinboats almost every day, so here goes . . .
I have rebuilt my jet jon twice now, & have been thinking of yet another tweak to make it better.
I have the plastic tunnel-motor mount glued & screwed in; it is set to be the low point of the hull.
In front of that,I have a tapered panel that extends about 4 foot fwd (It is actually the drop out from the big hole I cut for the tunnel).
I still get some cavitation when in a chop over about 2 or 3 inches It can depend on whether you are going into vs. with wind.
I am now contemplating adding a keel pad to extend farther fwd; the intention is to push the air farther to the sides. I also have a porposing issue above 30 mph, which I think is partly caused by the tapered panel being right at the planing break.
I am thinking of using UMHW plastic for this new keel pad, but most likely will prototype it with a fiberglassed panel 1st (as I could be way off-base).
I wish there was someone with software that could run simulations for these 1 off designs.
Edit - getting back to your question on spoons, I tried making one but it wasn't very effective. If I could have bought something like that already formed, it might have worked better for me. YMMV
Good luck on your build - post some photos!
Ok , good input. We get some wind here so I want to avoid cavitation as much as possible. I can use a customers press setup to punch out a spoon to weld in if I can get a design to him run through his tooling guys.
Do you think that 787 seadoo would push it 30 mph or no ? Will float boxes help porpoising ?
Yes on both those questions.
I made large trim tabs & that helped porpoising, along with making bow heavy. Those were band-aids though.
A big factor is the thrust angle of the pump nozzle.
