2075 commercial grade jon boat,
Couple more upgrades
Did you ever raise the console? Can't tell from pics. Looks like a great rig!
I haven't gotten around to it. Barely learning and getting the hang of tigging aluminum. Will eventually get to it.
I have been experiencing over splash at take off and some prop cavitation. I am in the process of installing an 8 inch plate straight across top of tunnel in hopes of achieving better water pressure to the prop. when my tunnel was designed and welded it was left flush with rear of boat. Ill post results as soon as i'm able to weld and try it out. Anyone else has similar set up or ideas.
Great day everyone
little update on the big ol girl,
this is my first try ant tig welding and bending aluminum,,
