Rewiring a johnson 25hp outboard
Joshua Stansbury
Knoxville, TN
Hey guys I'm rewiring a johnson 25hp outboard motor, and the harness that came with it I know went to another boat and the only thing they had hooked up was the ignition/key wiring. Can anyone tell me what these two things are?
Pic on the left is your fuel enrichment solenoid - Basically, it's a choke for cold-starting. It gives the motor a little shot of gas to help it start when it's cold. Purple/white wire from the harness powers it.
Pic on the right has several things. Your electrical terminal strip in the foreground and your rectifier/voltage regulator behind it.
Awesome! Thank you very much.
