Hi there, just completed a full rebuild. Has good compression. Confirmed spark. Brand new points. Brand new coils + condensers. Points set to .020. Confirmed fuel reaches carb. Here are the issues happening:
- i am getting zero “chug” or “cough” when trying to start
- when i pull start, fuel shoots out of the intake (carb leaking?)
- when i pull the plugs after doing a few pull starts, they do not smell like fuel at all (fuel isnt reaching the cylinder?)
I rebuilt the carb but its still the OE 1962 carb. High speed and low speed female ports worn down too much?
The points do not stay closed until the lobe comes around to open to .020. They are always open. Is this bad? I just installed brand new points. Used the richards outboard points setter for T and B cylinder timing- each set to .020. Used the richards outboard circle ring
My guesses:
- carb itself is bad, even with a rebuild in it?
- reed valve isnt allowing fuel into the cylinder? I installed new reed valves correctly via OE manual
- weak spark? But i dont smell fuel on plugs
My guesses:
