1990 Tracker Guide V14 restoration
bamalivin
Birmingham, AL
I came into my newest boat restoration over this past winter. I have had a good time learning and teaching my son over the process of the build thus far. It is a 1990 Tracker Guide V14 with a stock 1989 Evinrude 20 HP long shaft. I have replaced all the plywood floor throughout the boat and coated it with a high end waterproofing paint before carpeting. I also built a small casting deck on front. I have been bargain shopping for this entire build, so I found a used Minn Kota power drive trolling motor to install on Craigslist for $50. I also found a local battery supply that sells large reconditioned AGM batteries for $60 a piece. I purchased two, as my trolling motor is 24v. If you know anything about batteries, you know that this is quite the deal! The only downside is the weight, and they weigh ALOT! (~160 lbs) so I have been determining the best location for best weight distribution. I also installed a switch panel with built-in fussed links. It's waterproof and has a charging port for powering cell phones and such. I then installed a through hull fitting and new builge pump.
This is pictures when I picked it up. It was a diamond in the ruff, and is far from this now, but the build is continious as we learn what works for us and make modifications accordingly.
The durring:
through hull fitting for bilge pump, and wiring the new switch panel.
I appreciate it! It does have nice clean lines, which is one of the main reasons I upgraded from my previous aluminium. It is a pretty fast hull, and it should really scream when I finish my 20-35HP engine modification.
fl.graderman said:
Nice. I like the lines of that hull.
2015 Tracker Grizzly 1448 MVX
1996 Evinrude 25hp 3 cylinder looper
