I think it would create drag……I wonder what it would do if you mounted a hydrofoil under the boat to lift her out of the water? You may have to lose the jack plate to keep the prop in the water but that would be some mod.
A real hydrofoil (Not one that attaches to the anti-cavitation plate) lifts the boat out of the water. I can't see it causing greater drag. I'll drop a video for you later.I think it would create drag……
When I get some time I'll look him up and check out his builds.I watched his boat build...its the bottom of a RIB, he added the sides and gunnels...think its just under 9' and 90lbs...theres alittle v to the hull.
He has some interesting videos(to me), found him by looking to cup an aluminum prop( he has a video on that)
