67 evinrude remote steering bracket ?
Ironhorse2022
LOCATION
Brighton Michigan
Is this the correct bracket to convert a tiller motor (67 Fastwin) into remote steering ?
Ronbedard57
Seabrook Nh
Hi
Pretty sure that'll work. The oblong notches could be ground a bit to adjust the fit if you don't remove too much material. Make sure the tiller rope (plastic coated wire cable) you use is good quality and heavy enough so it can't slip off of the pulley and jam.
Good luck.
airshot
Appears to be the right connector, installed many in my younger years. The above post is correct, use a good quality cable to get the best performance, there should also be a spring at each end to keep the cable taught while it runs back and forth thru turning..
