71'V-Hull
Now that I got my boat and I'm going out on the water a lot lately and I've always used spinning rods/reels but it seems that every pro uses almost exclusively baitcasting set ups. I bought a rod and reel last year and never completely got used to it, especially the right hand retreive and then switching hands after the cast. It's spent most of its life sitting in a corner since I bought it. It was a shakespear at walmart, about $50, all metal and worked well with 12lb flouro. I just couldn't get used to right hand retreive and switching hands.
So, I was at Dick's the other day and found a pretty nice left hand retreive model on clearance (Pinnacle) and figured why not? I'll give it a shot. I bought some high end 30lb test braided line I think it was proline or something like that, spooled it up and put the new reel on my rod.
My first issue was that no matter how much tension I put on the line while spooling it, the line is thin enough that it will bite into its self and cause massive tangles after just a few casts. In fact, I had to cut out nearly 30 yards of line that got tangled and knoted up because of that. It made the rod/reel unusable while I was on the water the other night, I had to put it down and grab one of my spinning set ups.
Is there anything I can do about this? I suppose it might help if I went up to like a 12lb diameter/60lb test line but it just seems so ridiculous to use a line that heavy for catching largemouths. I've used 8lb mono for stripers around here and it does fine.
The other issue I have is, I like to throw light baits. The bass around here seem to be really picky, so one of my favorite things to do is snake a weightless senko or gulp worm and snake it slowly through heavy cover, or I'll use the same baits wacky rigged along the edges of pads and grass. I've found it nearly impossible to cast a baitcaster with anything less than around a half ounce on the line. Has anyone had luck throwing anything light on a baitcaster? What kind of setup did you use?
I definitely appreciate the advantages of a baitcaster but it seems like there's also a ton of strange quirks and other things just flat won't work at all. The sensitivity, especially with braided line is outstanding, as well as the accuracy and gear ratios, but the **** things just haven't been working for me!
I guess I'll try some 12lb flourocarbon and/or 60lb braid and give it another shot, I suppose I may be able to still use it as a striper rod, or maybe I can use it for heavy topwater frogs, jigs and crankbaits if I can't use the light stuff on it.
