- Joined
- Oct 1, 2011
- Messages
- 452
- Reaction score
- 229
- LOCATION
- SoCal
Considering battery placement for a bow mount TM (one 12V group 27 DC). I can place battery just behind the bow bench on front deck and would be the easiest way to carry the battery.
I am considering a cleaner, out of the way, place to store the battery. I was thinking directly under the bow bench but there is not enough room as the bow angle rises steeply and does not allow for a battery to sit directly under bench.
I was thinking about cutting a rectangular hole out of the bench seat and building a tray that drops into the hole and stops at a predesignated depth. This depth would be approx. 5"-6" (blue tape on battery box). The tray would be alum angle on top where tray would stop, and the tray where battery sits could be 1.5" aluminum flat bar or panels made the full length and width. All alum pieces would be riveted together using 3/16" blind rivets.
The battery box and battery would be housed in tray and lowered into hole. Weight is down lower than if mounted on top of bench, but not as low as if mounted directly under the bench at deck level. TM deck will be built to mount on gunnels above battery.
Thoughts?
Thoughts?
