Eoughphily
- Joined
- Nov 3, 2014
- Messages
- 5
- Reaction score
- 0
I installed a blue sea add a battery switch + acr a while back. I set everything up based on the diagram that came with it. It seemed like it was functioning, at least nothing smoked or caught on fire when turned on. It wasn't until later on I realized there was a status led but whether its charging or draining the battery, the led on the acr never turns on or flashes. I've done some basic troubleshooting , browsed the threads gone through the troubleshooting flowchart by blue sea and i cant figure out why it doesn't light up.
I confirmed the ground wire on the acr has a solid connection from the acr to the common ground. The common ground is shared with the acr and both batteries. The motor connects to the switch at the top to B1 (battery 1/starter battery) from the switch it goes to battery 1, another wire goes from battery 1 to the 60a breaker, then to the acr. From the acr is the wire for B2 (battery 2/house battery) to 60a breaker then to positive bus. From the bus, I have a wire going to battery 2 and another wire from the bus to the switch. From the switch it goes to the accessories fuse panel. I have a starter isolation wire plugged into the acr, but it currently is not being used, it us taped off for future use.
When I turn the switch on, I can connect my multimeter to the positive on each battery and there is continuity. Both batteries are between 12.2 and 12.3. When I connect a charger, only one battery is getting a charge, not both.
Im starting to wonder if my acr is a dud out of the box. I attached a photo of my wiring, if somebody can see anything wrong please let me know, I don't want to spend for another acr to find out it's my wiring and not a bad unit. Thank you in advance.
