Tin Man
- Joined
- Oct 1, 2011
- Messages
- 537
- Reaction score
- 336
- LOCATION
- SoCal
My tracker came with short (2') side load guides. They are about 2' above trailer frame. Unfortunately, many owner's of the newer PG V16SC models have experienced issues with side guide boards hitting the edge of hull mounted through hulls (cracking them) when loading boat onto trailer. The through hulls and side boards meet when boat is being retrieved at launch ramp. I believe the real issue lies in the t-hull. It is mounted approx. 1/4"-3/8" away from hull. It has a gasket seal that is either foam or rubber. This slight offset is what catches the edge of guide board when you are loading (see pics).
So, rather than wait til it happens to me....I am considering load guides that use PVC pipes that slide over square tubing uprights. I would remove the original side guides. Many brands of these post guides appear to be similar but it's the "hat" bracket that is used to clamp square tubing to frame that has me concerned. It looks like very thin gauge metal. Some guide posts use gussets on tubing for added strength, but most do not.
Here are a couple that I have found:
https://www.homedepot.com/p/Extreme...-Stainless-Steel-Hardware-3005-5542/325143154
https://www.vevor.com/boat-trailer-...e-on-with-2pcs-pvc-tube-covers-p_010672885465
Anybody use post guides and can comment on their quality, effectiveness, etc? Brand?
Thanks!
Thanks!
