Difference in Lowe 1667 and 1667T around 2000
Dave2506
LOCATION
Wisconsin
I am wondering what the difference is between a Lowe 1667 and a 1667T.
I have a 2000 1667, and am looking to do the Bimini top that drops into the oar locks.
So if they are basically the same, should work. If, not... well....
Lowe has a pretty good catalog archive. The pic below is for the 2000 model year. The dimensions for a 1667 and 1667T are identical. I assume the "T" stands for tiller, but am only guessing.
The 1667 T has a 21" transom and the 1667 has a 16".
Thank you.
So that is the difference then....
Makes sense since mine is close to 16 inches being a 1667. Therefore, I run a short shaft motor.
So the Bimini tops would definitely fit between the two, as long as they share the same lock spacing then...
