Evinrude 15HP help with model number, missing plate
chetsteadman
Can anyone help my ID the model number on this 15hp Evinrude I picked up? Would like to get it running and need to order the correct parts. The model number and serial number plate is missing. Based on some googling I think it’s a 1975?
FuzzyGrub
Rural NY
Welcome to Tin Boats. I can only say it looks like 70’s era Evinrude. Others will have a better idea, but there will be a broad range of years that parts will fit.
Crazyboat
NJ
I had a 74 Johnson, looked near exactly the same as I remember it, I'm sure not much changed on them in the half dozen or so years surrounding it.
LaqueRatt
LOCATION
Cedar Lake, IN
I don't know for sure, but in my researching motors recently I've read that there is a plug on the motor that has the s/n on it.
Attaching a couple pics of my '75 9.9 for reference. Think it's basically the same motor.
LaqueRatt
LOCATION
Cedar Lake, IN
Thought I should mention that these motors are notorious for having the upper thrust mount go bad. It's a rubber piece hidden inside that you can't see. Hard to find, not real easy to replace, and a used one if you can get it will likely set you back over a hundred bucks. Info here:
Sea Antsy
TinBoats Supporter
LOCATION
High Bar Harbor NJ
somewhere on the side, on a vertical surface of the block there is an aluminum disc about the size of a nickle or a quarter that has the model # stamped into it..
I always thought it was a freeze out plug ???
Duro
Ontario,Canada
I have a ‘79 evinrude 9.9 that looks identical to yours & I believe you’re correct that the 15 h.p just has
a different carb . Some guys use to swap carbs out for lakes that had 10 h.p max rules.
chetsteadman
I have heard this as well, didn't find anything like that on the inside. I will look again. Ordered a carb kit and fuel pump for a 1975, will see if everything is as it should be.
