Jeff F
Hi , replacing the head gasket on my 2003 johnson 9.9 HP 2 stroke model J10RSRD . Does anyone know what the torque spec is on the head bolts ?? Thanks Jeff
Jeff F said:compression getting in to cooling system ??
Jeff F said:RBW , yeah once I got the cyl head off I blew out the cooling passages in the motor and Cyl head especially the where the thermostat is installed and also where I have the lower unit off I also blew air into the water inlet pipe got good air out of the ports, my head gasket looks almost as bad as your picture Jeff
