Jhelms
Appreciate any feedback.
I have a 15' gregor H-51 / 66" beam V bottom (about 200ish lbs). I will be putting a 2004 9.9 honda four stroke on the boat. Motor has an se sport 200 foil and stock prop. I am limited to 9.9 as our lakes are either electric only or 10hp limited.
I hear a lot about how different props can really help with overall performance. Running the prop calculator for expected weight and setup on this site, I get the following recommendations:
- 9x9 Turning Point Hustler aluminum 3 blade
- 9x10 Turning Point Hustler aluminum 3 blade
I am seeing conflicting info on the stock 3 blade prop size and pitch - will have to see it I guess.
I do not expect a fast motor by any-means. But if I could get it to plane at maybe 10mph or squeek out a little extra speed, that would be nice.
Gear will be light. Fuel, battery, minor interior trim, poles and tackle. Generally 2-3 adults.
Any advice would be appreciated.
