- Joined
- Feb 3, 2023
- Messages
- 599
- Reaction score
- 532
- LOCATION
- Mead Washington
Hey, I’m curious how close anyone has mounted two transducers from each other on the stern. I have a couple of Helix 7s, with both transducers mounted on the stern. One is an SI and the other is a DI transducer. Using existing holes I mounted both about 3” apart side to side with the SI about an 1.5” lower. They are both on the starboard (right) side of the stern about 24” from the centerline.
When running both transducers the SI gets a thin dark line in the image every few feet of travel. I didn’t notice any reduction in the SI sensitivity but, it’s possible. The DI works fine with both on. Also, the SI doesn’t have any lines when the DI is turned off.
I’m considering moving the SI down and closer to the center line. This would provide about 18” of side to side separation and maybe 5 to 6” of vertical seperation. This would place the SI in front of the outboard. (I don’t need imaging from this traduced at speed.). Also, this would give the SI a very clear side to side view. Maybe I’ll try it first at trolling speed with the SI transducer mounted with some double sided Gorilla tape.
If you have successfully placed a SI and DI transducers near each other I’d enjoy hearing your experience.
This isn’t anything urgent. If moving the SI near the centerline doesn’t work I’ll just move to the port side of the motor or remove it altogether. Honestly, I can live without three helix 7’s in the same boat. I was just trying to find a use for the older DI unit and I had a big hole in the dash that it filled quite nicely.
