Brine said:Wow, that framing looks great. Are you guys using liquid nails as well?
Hard to tell from the pic, but normally people use untreated wood with a water sealer as opposed to pressure treated to prevent corrosion with the aluminum.
Looking forward to watching your progress.
captmig said:Wow,,, bummer!
A quick google on this and I got a lot of info. Wish I would have read a bit more b4 starting. I did read that a barrier between the wood and aluminum is all you need and paint can be that barrier.
Most of the wood was left over from a shed we built so $$$ was already spent for that project, I do have 5200 between the wood and the boat along with the paint. Also on the floor i added a strip of aluminum between the wood so that the water would not reach it. I guess time will tell as there is no turning back, and I definitely cant tell my old man cause he will rip it out and start over.
OH WELL!!!!
Have been reading up a bit on this and it seems the wood sold down here in FL at HD was a special treatment for this corrosion. Does not mean I am in the pink at all, but at least it is something. I guess I will be the Ginnie Pig for this lumber.
https://www.homedepot.com/hdus/en_US/DTCCOM/HomePage/Know_How/Buying_Guides/Building_Supplies_Buying_Guide/Lumber_Buying_Guides/Pressure_Treated/Docs/HDTreatingMap2009.pdf
https://www.homedepot.com/webapp/wcs/stores/servlet/ContentView?pn=Pressure_Treated&langId=-1&storeId=10051&catalogId=1
Nevillizer said:On a differant note that bracing looks stout as h e (double hockey sticks)! Rosey Odonell could fish on there.
captmig said:Nevillizer said:On a differant note that bracing looks stout as h e (double hockey sticks)! Rosey Odonell could fish on there.
Yes, she could but I doubt she would make it back from that fishing trip. ; ) :twisted:
