Mercury 2 stroke 65/45 jet
Creekchub
Anybody got any feedback on these older two stroke motors. I got two used boats I’m looking at. One has a 4 stroke 60/40 and the other has a 2 stroke 65/45. I like the boat with the 65/45 better but the motor is about 10 years older, which really doesn’t bother me but wanted to see what the opinions are of the motor before I dropped the cash
Thanks
A little more power and probably a little lighter weight, usually a positive in a jet boat. The boat and expected load will play a big role in its performance.
Outboard Jets makes just about all the production jets you see these days. Their website is a trove of great info. Here is a link you should read about boat hulls and recommended power. Boat/Power Select
I estimated all the weights in my son's 17' G3, and the power just made the minimum requirement. Just under a 2000lb gross weight with a 90HP power head. I think the minimum does provide "good" performance. If he opted for the smaller 60/40 jet, it probably would have been a mistake.
I have the 60/45 2 stroke on my boat and it's a short shaft motor due to the boat being a jet tunnel hull. I think mine is a 1994 model and has been a good motor but I did lose the voltage regulator/rectifier 2 years ago and the stator last year. So I replaced all the ignition parts with CDI stuff and so far so good. The oil injection pump was leaking bad so I removed the gear inside and run it with premix. Even with it being a short shaft, I had to mount it 2-1/2" above the transom to tuck into the tunnel properly.lowe_trimmed1.jpg
how much noise and fuel usage can you put up with? Both are considerations, and even moreso with jets.
I seriously dislike the sound of a 2smoke jet in action.
In this case though it may have to be weighed against the parts issue mentioned, though I have no expertise in this vein or several others.
I've had a 2 stroke Merc 60 /40 on an 1997 Xpress `1650 since 2002. Motor and is very dependable.
Every part is availabe used on Ebay or new and cheap. I estimate I've dunked my set-up a minimum of 600 times.
I moved batteries and helm forward and took-off the 2 of the 4 seats. The boat has two pedestal platforms.
it is beat to heck from river running for smallmouth bass. Top speed I ever saw going down river was 33mph one day one time when I had the liner perfectly adjusted. Going upriver It goes 28mph with 2 200 lb guys.
To save gas, when I am by myself I go about 27mph which puts me at 80% full throttle.
I would love a two stroke Mercury Optimax 115 with jet. But If it aint' broke why fix it ? So I fish with this outfit for 21 years now.
