Mercury jet Outboard 4 stroke
Raven205
Parkland County, Alberta
Anyone know what is the differnce between a 4 stroke Mercury 50/35 and a 4 Stroke Mercury 60/40?
They both have the same weight so I suspect they have the same motor. How does the perfomance compare?
Thanks
The block might be the same displacement but the first thing I would look at is the size of the jet pump. It might show the jet pump size on the outboardjets.com site. With the newer stuff being computer controlled, I would guess some differences there as well.
Probably ECU and impeller but I am not 100%.
i would not expect there to be a huge difference between the two, considering it's a jet
Same year? Probably nothing except for the tuning in the ECM. The current 75-115hp motors are identical aside from tuning, same with 40-60.
There is a company out there that can reflash the ECM but I forget their name.
