pin hole leak
clydegator
I have 2017, 2072 seark I just found a pin hole leak in the weld below the drain plug. What is the best way to fix it. Should I have it welded or just seal it?
Quickest, easiest, cheapest way right now is to use J B Water Weld on it. Just follow the directions and it should be (even probably WILL be) good for as long as you have the boat.
Small hole repairs are the strength of J B Weld.
Best wishes.
If tou know wherevthe pin hole is at, put a small taper on both sides of the hole if possible, then coat well with JB weld and you will be good to go.
