DownSouthGaBoy said:I would actually check at Lowes, Home Depot, or even an auto parts store for large rubber grommets, these are used to route wires through vehicle bulkheads (usually metal) and are to prevent the sharp metal from cutting the wire.
If they have one large enough for your application, use it. Also check it will fit through the thickness of your plywood deck.
You may even have to special order one from a site on the internet, but it will be worth it.
Just drill a hole through the deck , but make sure to cut out the circle in the carpet first or your drill bit will unwind your carpet (not cool, lol).
redbug said:the self sealing pipe cover would look like crap imo.... a gromet is the way to go
this is a product that is designed for running cables through the motor well they only sell wholesale but you can pick this up from any paets place
https://www.thmarine.com/product.cfm?PRID=103
Looks like the product would work well for your application, but I would highly advise you to look beyond that particular seller. In no way does it cost $8 to ship both of those. I just sent a 7 lb book to Florida for $4.91, from Washington State.Troutman3000 said:https://cgi.ebay.com/ebaymotors/UTILITY-BOAT-GROMMET-PAIR_W0QQitemZ190347691924QQcmdZViewItemQQptZBoat_Parts_Accessories_Gear?hash=item2c519b4794
I think I may get this.
