Prop size
CodyJ3188
Herrin, Illinois
I'm needing some advice on prop size...I've got a 1652 Alweld with a 50 hp mercury 2 stroke...8 inch jackplate...prop is 13×11...I believe it was on a pontoon before I bought it...took it out and ran it and would only get to about 30 to 32 mph and than it would seem like it was missing but it's not...I'm thinking I need to go to a 13 or a 14...suggestions please
DaleH
TinBoats Supporter
Eastern Mass
Use the Prop Calculator here NOW ... https://turningpointpropellers.com/PROPWIZARD/ and put in YOUR hull/motor and actual/honest weights for all gear carried, or pick a hull that is closest in match for what YOU have. See what that calculator tells you that YOU should be using for your exact rig and how equipped.
Zum
Nova Scotia
I have a 1652 (crestliner,also has a tunnel), anyways,had a dt 40hp Suzuki and used a 14 pitch. Only have a 30hp now but by myself sometimes Ill switch to a 13 pitch, normally use an 11.
Zum
Nova Scotia
Not sure why it says no war in my post...not my doings,doesnt show up when I go to edit
