Hi Everyone - I have a Tracker 170 and just upgraded to a 24v TM. Since there was no access to unbolt the old TM without removing the whole deck and since a recessed tray has always been on my list of eventual projects, I pulled the trigger and cut a hole for it. The only thing I am getting stuck on is how to run the drain tube. Does anyone know the best place to run it or done this before on a Tracker? I've done a lot of googling, but can't seem to find anything helpful. Can I just dig through the foam until i reach the hull and run it straight down to the bottom of the boat? Or do I need to run it somewhere specific (i.e. keel drain, if I even have one)?
In the pic you can see I started digging back and to the left, but it wasn't looking too promising so I decided to hold off on removing more foam for now.
I would appreciate any thoughts!
