This is mostly me thinking out loud and vetting if this is a good idea or not...
My 14' Smokercraft boat was inherited from my dad (so I know it's history since new) and has 4 bench seats with wooden tops. These wooden tops have been refinished before and will need some attention this year. I also know that after 40+ years of existence, I know that mice have removed foam flotation from under these seats. One thing that I really lack is any amount of built-in storage! There are always small odds-n-ends that I would like to stay in the boat at all times. Right now I use a tall, plastic "ammo box", but it's another loose item in the boat taking up floor space.
As I'm researching and brainstorming, I'm considering a couple of ideas:
- Replace the wooden bench tops with a material other than marine plywood; I don't want to be revisiting this project in the future, unless I want to.
I'm looking at coosa board, but open to other ideas/materials (e.g., Starboard, Azek sheets, etc.).
- Replace the foam flotation removed by vermin. Will need to see what has been removed to determine what I should do.
- Of the 4 bench seats, 2 have swivel seats clamped on. I'm considering installing some type of drop-in, sealed storage box, like this (probably different dimensions) in 1 or both of the remaining bench seats:
https://www.boatoutfitters.com/storage-bin-with-removable-tub-11x15?gclid=EAIaIQobChMI9Z-u7tv55wIVyrzACh1j6wA4EAQYASABEgLPt_D_BwE
I'm aware that it is never wise to blatantly remove flotation without making up for that loss, so I'm wondering if my approach is okay:
- replace the bench tops with a lighter weight alternative
- replace any missing flotation
- install 1 or 2 storage boxes that are mostly sealed (not sure if the air they trap can be considered "flotation")
Again, I'm just scoping the wisdom in this idea before I go any deeper.
Thanks!
Thanks!
