Sealing my riveted jon boat
Just Don
LOCATION
Lone Star Taxas
Thinking about sealing my riveted jon boat.
It doesn't leak but the boat is 57 years old and I'm older.
It was a free boat and trailer to me can't beat that I think.
I was wondering how to make it less like to ever leak or is
it silly to worry about it!
At 67 I'd like an easy way lol.
Suggestions please!
Y'all go fishing it's fun and good for you!
The easiest and cheapest is super glue. Warm each rivet with a hair dryer and put a few drops of superglue on.
There are better systems that work the same way.
Cool I just figured there was some type of spray coating.
I've had a number of older boats. If they don't leak a drop, you are good! If you have a leaky rivet or two, mark them and then "buck" them by holding a hammer on the inside or outside, and hit the rivet firmly from the opposite side to set it a little more firmly. One or two strikes is all you need. No need to flatten the thing out.
You could go through using epoxy, gluvit, flex seal, and a bunch of other goop, but if it doesn't leak, then why buy something that isn't needed? Fixing what ain't broke, as they say?
Does it matter though? Seems like I'm always sloshing a little bit of water into the boat. If I had a small leak doubt if I'd even notice.
I guess I did, I can see your point and I though so yet I wanted to ask.
